China Chemical Dosing Metering Pump
ffalivvv
Pays : weh
Messagepar ffalivvv » mar. 13 avr. 2021 09:46
Special Performance
鈾?Easy for application and simple operation, simple installation.
鈾?Small size, low noise, accuracy control.
鈾?Measures more objectively and precisely, 0~100% adjustable flow range.
鈾?corrosion resistance
鈾?It is useful for clarification, waste water treatment, laboratory, and other little flow dosage.
2JT Duplex Heads Plunger Metering Pumps
ModelFlow
(L/h)Pressure
(MPa)Plunger Diameter
(mm)Route Range
(mm)Reciprocation Frequency
(rpm)Motor Power
(KW)SizeWeight
(Kg)
DNDKdh1h2L
2JT-52/645264128090489565461891891250750
2JT-78/647864158090489565461891891250750
2JT-92/509250168090489565461891891250750
2JT-138/5013850208090489565461891891250750
2JT-152/4015240218090489565461891891250750
2JT-228/4022840268090489565461891891250750
2JT-240/32240322780905.51210585561891891250750
2JT-360/32360323380905.51210585561891891250750
2JT-392/25392253480905.51210585561891891250750
2JT-588/25588254280905.51210585561891891250750
2JT-610/20610204280905.51611585651941941300750
2JT-900/20900205280905.51611585651941941300750
2JT-1016/161016165580905.51611585651941941300750
2JT-1500/161500166780905.51611585651941941300750
2JT-1666/101666107080905.52612598752002001350750
2JT-2500/102500108680905.52612598752002001350750
2JT-2288/8228888280905.52612598752002001350750
2JT-3432/83432810180905.52612598752002001350750
2JT-3100/6.431006.49680905.53512598752002001350750
2JT-4650/4.046504.011780905.53512598752002001350750
2JT-4000/2.540002.510980905.53512598752002001350750
2JT-6000/1.660001.613380905.540145110852352351350750
2JT-9000/1.690001.616380905.540145110852352351350750
2JT-7320/1.073201.014780905.5801951601352702701350750
2JT-11000/1.0110001.018080905.5801951601352702701350750
2JT-15500/0.5155000.521480905.5801951601352702701350750
2JX Duplex Heads Plunger Metering Pumps
ModelFlow
(L/h)Pressure
(mm)Route Range
(rpm)Motor Power
(KW)SizeWeight
(Kg)
DNDKdh1h2L
2JX-8/258251022800.75890604116216376078
2JX-14/1614161322800.751690604116216376078
2JX-22/1022101622800.751290604116216378078
2JX-38/6.4386.42122800.751690604116216378078
2JX-62/4.0624.02722800.552090604116216378078
2JX-125/2.51252.53922800.552890604116216378078
2JX-250/1.62501.65522800.554095604616716778078
2JX-310/1.23101.26122800.753295604616716782078
2JX-390/1.03901.06922800.754095604616716782078
2JX-500/0.55000.57822800.754595604616716782078China Chemical Dosing Metering Pump
website:http://www.sfchemy.com/chemical-dosing-metering-pump/
